Using Dual Table for water injection control
g60peru
Post by g60peru »
Has anyone tried to use Dual Table mode and set VE Table 2 and the INJ-2 output to control a water pump for water injection? It would be kinda PWM for the pump.
That way you could have gradual injection, proportional to MAP and RPM instead of the typical on/off water injection.
Eduardo
Tadek
Post by Tadek »
Not the way you are describing it, but I am using the second table to control the high speed solenoid valve offered by ERL/Aquamist.
I used to run the 2d system before this, which has a controller, which again uses the signal controlling the fuel injectors to inject the proper amount of water.
Cheers,
Tadek
