Ignition input capture: How to know what to use?
Posted: Sun Jul 30, 2006 9:36 am
Ms-II, V3, 2.34 code Hall sensor with pull up resistor
I'm in the middle of trying to set up my ignition and I don't know what to use as my ignition input capture. I have read the configuration article and tried running the engine both ways. Normally, a 'positive going' pulse would usually mean a pulse seen by pin #24 on db-37 that is +12v or +5v? And since it is inverted by the opto-isolator, that means falling edge would be the input capture?
Since I'm using a hall sensor that pulls a voltage low , the pull up resistor actually pulls it to +12v or +5v. This would be considered 'positive going' and again, the opto isolator inverts the signal. So I would assume I would choose falling edge for my input capture? Am I correct so far? This is what confuses me and I'm still learning the basics of this stuff. Correct me if I'm wrong. thanks.
