coilpack help needed
bens_cab
Post by bens_cab »
hi guys ive biined the cop setup as i think it was my problem so heres what i have
i got a wasted spark coilpack from a peugeot 306 it has 4 wires
1 white
2 blue
3 green
4 earth
how do i fins the 12v
my mate has the same coilpack on his car but has different coloured wires to me he has this but were not sure what they do
1 yellow possible signal
2 red possible 12v
3 yellow possible signal
4 black earth with connector for bolting to head
so do i go with his wiring hes using emerald on his 20vt
also would i need to adjust anything in mt or the ms for this pack im using 2xvb921s does it need them?
ptegler
Post by ptegler »
Is the coil pack wired so all three coils at one end are tied together? Is that point hardwired to a earth ground mount point? If not just wire the common terminal to +12V, the other ends of the coils to your VB's.
Paul Tegler
ptegler@cablespeed.com (ptegler@cablespeed.com)
www.teglerizer.com
----- Original Message -----
To: megasquirt-ignition@msefi.com (megasquirt-ignition@msefi.com)
Sent: Sunday, July 30, 2006 10:54 AM
Subject: coilpack help needed
1 white
2 blue
3 green
4 earth
2 red possible 12v
-------------------- m2f --------------------
This post is at:
http://www.msefi.com/forums/viewtopic.p ... 544#133544
Posted by email.
ptegler
ptegler @ cablespeed.com
My Success story: http://www.msefi.com/viewtopic.php?t=21806
Home site: http://www.teglerizer.com/Injected_Spit6.htm
bens_cab
opps
Post by bens_cab »
sorry its a 4 cylinder 1 coilpack with 4 wires and 4 plug leads think there known as a dispack
pin 4 has a radio suppresor which is bolted to the head its just 1,2,3 that im not overly sure about
dont want to get the 12v in the wrong place a fudge the coilpack
PSIG
Post by PSIG »
The pic below is from a random 306 wiring diagram on the web and it may not be for your model year. It would indicate that pin 3 is the common +12v power, pin 1 to Coil1 for plugs 1/4 and pin 2 to Coil2 for plugs 2/3. This would also support the assumption that pin 4 comes from the common power feed to the external noise suppression capacitor. Verify your info.
A way to crosscheck would be to compare resistance readings between pins. Using the picture in this case:
3/4 almost zero resistance
3/1 low resist
3/2 low resist
1/2 higher resistance about double 3/1 or 3/2
Hope that helps,
David
bens_cab
resistance
Post by bens_cab »
ok the last post was about the resistance just done this test and found this
if i hold the com probe onto pin4 then test i get this
pin 1 to 4 =1.7
pin 2 to 4 =1.7
pin 3 to 4 =1.2
so if ive read this right pin 3 is 12v and 1&2 are signal ?
bens_cab
or this
Post by bens_cab »
or this testing all the pins together
pin 2&3 =1.8
pin 3&4 =1.2
pin 1&2 = 2.3
