So, I'm excited to get off work and try the proper plug wire config., should make all the difference in the world.On a 6 cylinder engine, the coils in a 6 terminal pack fire ABC (left to right with the connector on the bottom). Coil A fires first and should be connected to cylinder #1 and its complimentary cylinder. The coil B should be connected to the cylinder that fires after #1, and its complimentary cylinder. the remaining two cylinders should be connected to coil C.
Will I need to reset my trigger offset now too since although I was clamped (timing light) to the number 1 plug wire that wire was actually connected to the number 3 (I think) coil pack tower?
Fred
