No cranking pulses to injectors??
Posted: Sun Jul 09, 2006 5:26 am
My engine won't start!
I'm running a MS1 V2.2, just upgraded to code 29q and squirt' n spark.
The car worked fine with the old 8x8 MAP only firmaware.
If I pour some petrol town the throttle body, it fires up straight away and idles, hence I've been able to adjust idle, and the system seems to be working fine apart from when I try to start.
I allso take this as an indication that It's not a flooding issue.
I have changed cranking PW up and down with no aparent results.
Whn I look at the run-time display, it shows no PW during cranking.
Is this normal, or an indication that something is wrong??
When the engine is idling, the runtime display shows PW.
Can anybody give me a hint about what my problem might be???
