Beginner Tuning
darrens
Beginner Tuning
Post by darrens »
Managed atlast to get round to firing the RV8 up this weekend, have megasquirt II V3 controling fuel only at the mo. Using rover plennum chamber and injectors. Ran rough as a dog to start with but manged to smooth it out a bit. Tons more to do tho before it's right.
One question, I seem to be getting a Ignition advance reading of around 90 degs from MS, somehow this don't seem right, static timing is set at 6 degs and when running with vacuum disconnected about 11-12 degs. (Idling a bit fast at the moment - strobe)
Anyone got any comments as to why I'm getting this reading
Using MSII V3 code 2.36 MT 2.25
Darrens,
Have you done the trigger wizard timing calibration? <http://www.megamanual.com/megatune.htm#og>
Are you seeing 90 degrees in MegaTune or on a timing light? I suspect you are seeing this in MegaTune, that you have the trigger offset set very high, and that MegaSquirt is actually sparking the next cylinder from the one it thinks it is (since V8's fire at 90 degree intervals).
darrens
Post by darrens »
Ah, gotch ya,
Missed that bit, thanks for that
Darren
darrens
Post by darrens »
I'm confused!!
Maybe thick!! When using the trigger offset tool in MS, I have previously set the timing with the timing light (strobe) to manufactures figure of 10 degs at 1200rpm with vaccum disconneted to distributor. (i.e aligned the markings)
Very good.
However I do get an extremely high ignition advance reading in MS. (60+deg not 90 as previously stated)
Quote from manual
"So in the above example, we wouldn't know how to adjust it, because we are missing the timing light info. But if the timing light showed 28.3 degrees, we would change the trigger angle to 10.0 . This takes 2 degrees out of the timing (because MS-II only adds 26.3-10 = 16.3 degrees, instead of 26.3 - 8 = 18.3 degrees), and the big number should match the timing light, so your trigger offset is correct"
I understand the theory of the trigger offset but am baffled as to how I'm to get figures to match (as the timing light is only a strobe), How to I get the seamingly incorrect 60+ degs to read correctly
I would point out that the distributor is on points at the moment (not ideal I know but long story) and controlling fuel only,
Any help appreciated
Thanlks
