Firmware help
QuarterHorse
Firmware help
Post by QuarterHorse »
So I downloaded the latest version of megatune, and I got the latest version of firmware 029q. I go to set the .ini file in the megatune, and there isn't an 029q, but an 029c. Obviously this wont jive, so can sombody help me out, I've searched my eyeballs out and can't find either one!
2713ddddavid
Post by 2713ddddavid »
You need to copy the .ini file from the 029q file into the Megatune directory.
The 029q file should have a .bat file called "copy.ini". Clicking that should copy the file to where it needs to be in Megatune.
QuarterHorse
Well I loaded 029q firmware. Copied the .ini file in the 029q file, selected the .ini file in the megatune, and now it still tells me the same message that the .ini file and the code don't match. Any clue?
newtyres1
Post by newtyres1 »
Try copying the 029q msns-extra.ini file into C/Program Files/Megasquirt/car1/mtcfg and see how that goes.
Ian.
