Posted: Sat Jun 24, 2006 4:01 pm
by sidney
Personal hy, I do not speak very well English, but necessary of the aid of yous, I am mounting a system of eletronica injection in a 750 XTZ necessary Supertenere and of some tips. My first problem is the collector (body) of the injection, I wanted to know which motorcycle or vehicle I could use to adapt? Which the sensors that would be necessarios for the project? The use of the MS in motorcycles is correct? Thank you,
Sidney
Posted: Mon Jun 26, 2006 7:00 am
by fscott
Sideny,
I'll see if I can answer your questions.
For the throttle bodies, you need to measure your caburators. You need to know their diameter and the distance between them. Once you know that, take a look here
http://www.msefi.com/viewtopic.php?t=6627 and see if anything looke like it might fit.
Sensors. You need an air temperature sensor to go in the intake. You need a coolant temperature sensor if you rbike is water cooled. If it's air cooled, then you need an oil temperature sensor or a cylinder head temperature sensor. And lastly, you will need an oxygen sensor.
MS Will work on a motorcycle.
I hope this helps you out.
Fred
