Can't idle with 550 cc/min injectors on 1.6L turbo ?
Posted: Tue Jun 20, 2006 7:51 pm
Greetings from Florida.
I've got a turbocharged 20V silvertop Toyota engine on which I've installed MSII V3 w/EDIS. With the thorough information in the technical manuals and the breadth of knowledge on this site, I've been able to get the car running very well and I've had a great time along the way! The car runs really well under all conditions: idle, cruise, acceleration enrichment and WOT w/8 psi of boost. It runs at least as good as my stock cars
Up to this point I have run the factory 330 cc/min high impedance injectors. When tuning I reached a point at which my duty cycle reached 100% in 4th gear under full boost. So I knew an injector upgrade was necessary. Compatible side feed injectors typically come in 440, 550 and 660 cc/min. After checking the calculations for injector sizing on this site I felt the 440s would just come shy of allowing me to meet my desired target of 280 HP without exceeding 80% duty cycle, so I selected 550s.
I checked the idle PW calculation, as clearly outlined in the MS technical manual as follows:
PW = REQ_FUEL * VE * MAP * E + accel + Injector_open_time
PW = 4.9 msec * 30% * (25 kPa / 100 kPa) + 1.0 msec = 1.36 msec
I realized this was getting very small for the idle PW but after reading all the posts on this forum I saw several people say they have been able to get good idle control on similar sized engines using 550 cc/min or larger injectors.
But I can't
. After reducing my VE table to 1%, my idle AFR is still incredibly rich and the car will no longer idle. I have to feather the throttle to keep the engine running at which time it just revs from 1k to 2.5k and back down again. With the 330 injectors my ReqFuel was around 13ms. The calculator computed a value of 4.9ms for these 550 cc/min injectors and I figured I could always reduce it further if I had a problem. But I’ve tried reducing the ReqFuel to 3 or 1 ms and that has no perceptible effect on AFR or idle stability.
To make sure I wasn't doing something silly, I swapped the 330's back in, reloaded my old tune and the car idled and ran like a clock again (to my relief ;)). I then ordered a second set of 550's thinking perhaps there was a problem with the first batch, but there's not much difference (if any). When trying to tune the idle, I've disabled EGO and the acceleration & decel enrichment but I still can't get the car anywhere near an acceptable AFR or eliminate the wild hunting.
So I'm wondering if I'm just trying to get way too large of an injector to meter the small amount of fuel required to idle or if there are additional items I can check and adjust to fix this problem. I am using the standard IOT of 1ms and I've tried 1 and 2 squirt strategies.
Would low impedance injectors be of any benefit? Or should I just throw in the towel, purchase 440s and just accept the HP limitation of those injectors? Thank you in advance for any assistance you can provide. I apologize if this question has been answered elsewhere on this site, as I have searched and searched and cannot find any more ideas to explore. Alternatively, I would like to hear from some of you who have relatively small engines using 550 or larger injectors with a ReqFuel of 5 ms or less IF you've been able to get your engine to idle at anything better than 10:1 AFR
. Thanks!
But I can't
