MS2 v3 with edis4 losing rpm signal(solved)
How can I check the edis module? or does it sound like something else. I have re checked the wiring and confirmed both the module and the coil are getting 12V.
Scott
jsmcortina
- MegaSquirt Guru
The EDIS module will spark with no intervention from the Megasquirt. No spark means a problem with the EDIS wiring (or less likely the module.)
The most frequent problem is VR sensor wires the wrong way around.
James
Reversed sensor wires...
Hytek Automotive
Portage, WI
'68 Hemi Dodge Super Bee
jsmcortina
- MegaSquirt Guru
Test for spark and if there is none swap the VR wires and test again.
If still no spark you need to re-check all of you wiring and make sure the coils and EDIS module are getting 12v during cranking.
James
