Changing EGO Gauge to AFR Readout
Posted: Sun Jun 18, 2006 3:40 pm
by DeneOehme
Is it possible and if so how, to change the EGO voltage gauge to an actual AFR ratio gauge. I'm using a MS1 (fuel only) and Meagtune 2.25, latest version.
Thanks in advance,
Dene
Posted: Sun Jun 18, 2006 4:11 pm
Dene,
If you have a wide-band sensor and have selected the appropriate controller when setting up in the configurator, then you should already see an AFR gauge (at least you should in most code INI files). If you don't, go into the configurator and set the 'Settings.ini/Settings/LAMBDA_SENSOR'.
If you have a narrow band sensor, then no, you cannot legitimately display the AFR, since the sensor output only corresponds to a particular AFR at one voltage (stoichiometric at the switch point voltage). That doesn't mean you can't make an AFR gauge, but it does mean it will be wrong, and by quite a bit, more often than it is right.
Posted: Sun Jun 18, 2006 5:52 pm
by DeneOehme
Thanks for that but I've done that and still only have EGO voltage. I do have a wideband.
Posted: Sun Jun 18, 2006 5:57 pm
DeneOehme,
What processor and code?
What version of MegaTune? If you aren't using the latest version of MegaTune, you should upgrade:
http://not2fast.wryday.com/megasquirt/mt/2.25/
Posted: Sun Jun 18, 2006 10:38 pm
by DeneOehme
Not sure what processor and code. About three years old if that's any help. How can I find this out? Downloaded the latest Megatune a few days ago.
Dene
