edis cut out and in
uwulff
edis cut out and in
Post by uwulff »
Have edi on my BMW 3.0csi .New for meRunning Megsquirt II .Driving along .Feels like someone turns off the egnition then on .
The edis-6 coil pack has 6 spark plug wires on it, is coil A closest to the end with the plug on it? B in the middle and C at the other end?
uwulff,
Can you post a datalog and a settings file?
It may be that the EDIS input signal is weak, and there are a few options to improve the sensitivity of the Hall circuit: http://www.megamanual.com/ms2/inputHEI.htm (you would need to do either the transistor mod or use the VR input circuit mod to avoid changing the input trigger edge).
Minami Kotaro
Post by Minami Kotaro »
Are you running resistor plugs? Mine did the same until I went to resistor plugs.
1967 VW Beetle
v2.2 board, MSNS-e 024s11
Check out my ongoing success story.
