VE table, is there a way to extend it?
Posted: Tue Jun 13, 2006 10:22 am
the VE table is 8 * 8. I know you can change the rpm ranges across the bottom and the map increments along the side. I have done this so the rpm starts at 800 (idle) and continues in even increments till 7000 (redline).
What i'd like is to make the table say 12 * 12 so that the Rpm to Map can be even more fine tuned. That would alow me to tune in 500rpm increments instead of 800. Boost kicks in at 3000-3500 but my tuning increments can only span the 800 rpm increments, I'd like to get a closer value range that would make the plots on the graph more accurate.
Is there any way to change the 8 * 8 table to a custom size?
