EDIS timing
Scott Bruce
EDIS timing
with EDIS all conected, will MSII 3.0 board change the timing to less than the 10 deg. limp-home mode? will it go into retard timing under boost pressure if you set it in the ign table?
Scott Bruce
Minami Kotaro
Timing will be whatever you set it to in normal circumstances. Mine goes from a maximum of 34 degrees BTDC at 100kpa and below to about 17 degrees BTDC under boost.
v2.2 board, MSNS-e 024s11
Check out my ongoing success story.
(of course!) injected 13B rotary.
