Idle kpa around 50, what could be the problem?
Any help would be greatly appreciated.
The most common causes of high idle MAP are timing, tuning and vacuum leaks (a plugged exhaust, cam timing off, poor compression, leaking valves, and a malfunctioning PCV valve can also do this). Keep working on the tuning, people often find they can lower the idle kPa 10 or even 15 kPa as they narrow in on the optimal tune. The procedures are in the manual.
