Megtweak3000 and MSnS-e for MSI and 29q2
ptegler
Post by ptegler »
anyone out there attempting to use megatweak3000 on the latest release of MSnS-E 29q2 ever get it to work correctly? It seems like mt3000 will not handle the 12x12 tables or something along those lines.
Any info on reconfig'ing megatweak3000 for the lastest and greatest code for MSI would be greatly appreciated.
ptegler
ptegler @ cablespeed.com
My Success story: http://www.msefi.com/viewtopic.php?t=21806
Home site: http://www.teglerizer.com/Injected_Spit6.htm
keithmac
Post by keithmac »
Have you tried setting MSLVV Compatibility in the msns-extra.ini and removing all the MARK points and Signiture with notepad?
I`ve also been experimenting with AutoTune and it woks wonders! maybe a better bet as it alters the VE map in the fly (just remember to Burn to Ecu before you turn the MS off..).
Squirted VW GTI 16vG60 mk2
ptegler
Post by ptegler »
Will that take care of the differences in the 8x8 vs 12x12
table formats?
Your statement leads me to believe that those ini file
changes will make MSLVV read the log files as well? (as
currently it won't)
I see Megatune 3.0 is setting up to handle 12x12 tables
for the AFR as well. So does the suggested ini file
changes correctly handl the idea that mt255 is 12x12 for
VE and spark, but only 8x8 for arf?
thanks
ptegler
On Wed, 07 Jun 2006 11:09:34 -0700
>Signiture with notepad?Squirted VW GTI 16vG60 mk2
> _________________________________________________________
> This post is at:
> http://www.msefi.com/viewtopic.php?p=124350#124350
Paul Tegler
ptegler@cablespeed.com
Posted by email.
keithmac
Post by keithmac »
Are you running MS1 or MS2? MS1 will never have a 12x12 AFR table as far as I can see (unless someone codes it in as an addition), I find the 8x8 table more than adequate. I read logs in MSLVV using the 029Q2 and the .ini mod, works a treat.
ptegler
Post by ptegler »
Thanks for that info. I'll have to take a look at it
tonight an see where it's currently set.
thanks again
oh... MS225 029q2 MSnS-E 29q2 on a V3 board running crank
triggered wasted spark
ptegler
On Wed, 07 Jun 2006 12:16:52 -0700
>works a treat.Squirted VW GTI 16vG60 mk2
> This post is at:
> http://www.msefi.com/viewtopic.php?p=124362#124362
Paul Tegler
Posted by email.
