rough running
rough running
Please lemme know thanks.
mops
- Experienced Squirter
generally idle timing should be anywhere form 5 to 20 degrees BTDC, try with 10 or 12 for a start.
idle air is crucial... too much will cause rolling idle - idle going up and down all the time.... called rollind because if you look at yout grrrn point in the fuel map it will be going around circular motion
too little idle air will make engine weak to the point of not being able to run without throttle.
about making your ve table smooth - what you actually want is a stable pulsewidth +- 0.2ms is still considered ok, but if it is -+ 0.5 it will be feelable....
let me know how you went.
