Problem with connecting to megasquirt
EstateAgent
It happened the other day to someone I was walking through, it would connect and read ok, but when writing to the MS, it would give page errors and such, 'til I realised that MegaTune was set for the wrong Firmware.
Reconfigured MT and voila!
hyperman,Is it possible that it cannot connect due to the fact that the sourcefile i want to use was made with a different code version?
I am not sure what you mean. Your INI file (and CODE_VARIANT) must match the code you have installed.
For all standard versions of the code, there is a matching INI file. If you have created custom code that uses the sertial interface to pass any 'non-standard' values, then you must create an INI file that matches the code.
I also check all the wiring and the reading were ok. My guess is that my laptop is the problem. I took an old laptop from work to try it out but this one only has a 8 bit transfer and MSII is set on 16 bit.
I have also rewrote the file to my ini code and this took care of almost all the warnings I first got.
When is try to download a file (with right ini) I get another error mesage saying: Controller voltage too low for reliable flash burning.
When i measure the 12V it gives a reading 11.5 on both the ecu and de msII side of the harnass. I'm starting to get a little confused because to my opinion the msII should get sufficient power the work properly.
Right click on one of the gauge in MegaTune, and swap to voltMeter. Then that gauge will tell you what MegaTune thinks the voltage is.
If it is below 10 Volts (8 on the stim) then look closely at R3 and R6 to make sure they are the correct values, properly soldered, and not solder bridged to adjacent components.
However, if the actual voltage is good, you can ignore the 'voltage too low' warning - I do it successfully on my alpha GPIO board all the time (it doesn't have a battery voltage circuit yet).
