MS2 Coil Control
mrbill
MS2 Coil Control
Post by mrbill »
I have yet to wire my car, but I am going today to buy a new coil and stuff for the car.
Does MSII just ground the coil at the appropriate time? If I am reading correctly, it get a switched 12v and then the pin__ grounds the coil for a correct fire.
I have looked through the manual, and also through megatune. There is a window devoted to igniton, and if I set it on ""standard coil charge" and play with the rest, I should have a car with computer-controled ignition, right?
I have an 82 volvo 242 if it matters guys. Thanks.
I just bought MSII
I have a 82 Volvo 242 turbo intercooled
mrbill,
Yes on all counts. MegaSquirt grounds the coil through the VB921, so it can control the timing (assuming you have a distributor to route the spark to the correct cylinder at the correct time).
mrbill
Post by mrbill »
lance wrote:mrbill,
Yes on all counts. MegaSquirt grounds the coil through the VB921, so it can control the timing (assuming you have a distributor to route the sprk to the correct cylinder at the correct time).
I most certainly do:) Thanks for the quick response! You guys are really awesome.
I just bought MSII
