noobie trying to get it right the first time.
randomtask1
from what i can tell, i can run my 24 tooth NE signal into the TachIn using the Vr curcuit. then i have to splice the G1 and G2 together and use a HEI 4 pin to condition it. then i run this into pin 11 of U1, the MS2 duaghter card.
does that sound right? thamks for the help.
78Spit1500Fed
- Site Admin
The MSII daughtercard and its associated firmware does not have wheel decoding software required to make any sense out of your crank/cam wheels.
All the documentation referrs to MegaSquirt & Spark-Extra firmware on the original MegaSquirt processor becuase that is the firmware/hardware that will support it.
I believe the development of wheel decoder software has been offloaded to the routerboard, though I'm nearly positive that our resident software guru, jsmcortina, has done some work in that area.
Perhaps he can comment.
-Brian
