Car won't start, no fuel
Posted: Wed May 17, 2006 7:18 pm
by HckyMstr19
I am getting fuel in the fuel rail and my FPR 1:1 is showing presure increasing, but when i go to start, the engin cranks but no fuel is being released into the cylinders, i removed the spark plug after cranking and no fuel at all, i checked my wiring for my MS and everything is wat it is supposed to me. I might also add that i just recieved used injectors from a 99 GST which i believe are 450cc low impedance, i either believe it to be the injectors r all bad and wont let fuel flow through which i believe is highly unlikely, or the MS is not giving the injectors the signal to open to release fuel, and help would be great
Posted: Wed May 17, 2006 7:20 pm
Posted: Fri May 19, 2006 12:51 pm
by HckyMstr19
i did look at all the tips and ive tried anything, is there a way i can test the voltage going to the injector harness or something, cuz i am sure im getting no fuel in the cylinders
Posted: Fri May 19, 2006 12:55 pm
HckyMstr19,
Yes, you can look for 12 Volts on one pin of the injector connector with the key on. To test MegaSquirt itself, a stim is the best way - does your MegaSquirt work okay on the stim?
When you are cranking, does the LED nearest the DB9 serial connector flash? If not, you are not getting a tach signal.
A good idea is to make a datalog of a starting attempt and post it here.
Another good idea is to tell us which of the troubleshootiung steps you tried, and what was the result of each of these tests.
