EFI without TPS possible ?
Posted: Tue May 16, 2006 2:29 pm
by Nickel_5000tq
It s not possible to add a TPS on a 100Q 1989 Audi 2.3l 5 cyl. throttle body.
I would like to test a MS without the TPS.
MS-1 V3 2.25 MT.
29f1
Posted: Wed May 17, 2006 8:41 am
by Turbo4V
The TPS is definitely not mandatory, you may be able to use MAP enrichment completely to do acceleration enrichment (that's what I do), thus eliminating the need for the sensor. The only other thing you loose is the ability to flood clear. I believe you need to ground the TPS sensor input if you're not using it, otherwise the TPS value will increase over time.
Justin
Posted: Wed May 17, 2006 9:53 am
by Nickel_5000tq
Ok.
I ll look at it.
Its what i was thinking too. i ll try and see.
thanks
