idle speed????
Posted: Mon May 15, 2006 2:10 pm
by fiat132
does anyone know what cold idle speed i should be running with one of these things????
ms1 v2.2
Posted: Tue May 16, 2006 8:11 am
by Jedrik
That looks like a valve, I don't think it has a cold or hot idle speed. It just opens and closes.
Posted: Tue May 16, 2006 8:17 am
by RNash
That would depend on a lot of variables, such as your engine displacement, and the size of vacuum source you have it connected to. But if it fully opens when cold, it should be close to the same rpm you would get if you disconnected the vacuum side while running.
Posted: Tue May 16, 2006 11:16 pm
by arnold
Hi Fiat 132 (nice car!), I use the same valve and decided to 'test' it by putting a manual valve in front of it. I want to know if the engines 'needs' the extra air at different temperatures.
Posted: Wed May 17, 2006 5:35 am
by fiat132
thanks man....
what did u find out.....i tried it and it seemed to need the extra air...
my idle speed is set to 850 but when i start it it idles around 700...i am sure it should be around 1100 with the valve opened...its giving me a hard time as sometimes the rpm drops and afterstart enrichment kicks in and the car runs very badly...until its fully warmed
i checked out your site....good stuff
Posted: Wed May 17, 2006 7:11 am
by arnold
I haven't tested yet, coming days I will. Mine also falls back into cranking
Posted: Wed May 17, 2006 3:11 pm
by fiat132
its very annoying.... i am glad to hear that the same thing happens with you...i dont really mean that
its just that i thought something might have been wrong with my ms
Posted: Mon May 22, 2006 12:26 am
by arnold
tested it, the engine needs the air..... but I still have idling problems
Posted: Sat May 27, 2006 8:28 am
by fiat132
i advanced the timing on my car which raised the idle speed...but it still goes into after start enrichment for no obvious reason
Posted: Sat May 27, 2006 1:40 pm
by arnold
what is the result of that?
