What output on a MSII V3 can I use for a cooling fan.
IcantDo55
Post by IcantDo55 »
I been searching the forum and can't find the answer. Its going to trip a 75amp relay for the cooling fan. The output from the MS is going to ground to turn it on, right?
Thanks and sorry for the stupid questions. There will be more soon, I should be fireing it up shortly.
-Mike
http://www.IcantDo55.com
89 Mustang A4 Block, bored & stroked 349 cid, AFR 205's, Edelbrock Victor 5.0, Paxton Novi 2000 SC, Tremec TKO.
krisr
Post by krisr »
I'm using the FIDLE pin to switch negative to 2 x 40A relays for my cooling fans. So far haven't had an issue. Make sure you use the code v2.36 and configure it up in the spare ports part of Megatune.
Sydney, Australia
IcantDo55
Post by IcantDo55 »
krisr wrote:I'm using the FIDLE pin to switch negative to 2 x 40A relays for my cooling fans. So far haven't had an issue. Make sure you use the code v2.36 and configure it up in the spare ports part of Megatune.
Thanks :D
-Mike
IcantDo55,
In general, you should search the manual as well: http://www.megamanual.com/mtabcon.htm. In this case, you would find the spare outputs under MS-II at: http://www.megamanual.com/ms2/spare.htm
