VW 16v ITB vacuum and ISV question...
Posted: Mon May 08, 2006 5:29 am
I have a VW 1.8 16v engine with ITB and CIS at the moment, but i'm going to megasquirt.
My itb's didnt have a vacuum supply, so i drilled 4 holes in the manifold, one for each runner, between the throttle plates and the valves.
I've put some plugs in the holes, about 5mm, and attached a hose to them, which goes to a little "canister" from where the vacuum goes to the brakebooster.
The other side of the "canister" used to go to the ISV, but then i lost the brakebooster, as the other side of the isv went to "atmosphere" (manifold between the throttle plates and the CIS air meter)
I blocked this end with a hose and bolt, as seen on picture. ( goes under the "manifold")
When i'm converting to megasquirt, will the vacuum be sufficient for the MAP sensor, if i attach it to the "canister" and will i need the ISV for idle control? (And how should i attach it?)
I the first picture you can see the "canister" and the hoses, with the orange arrows.
The second picture shows the ITB's, the orange point is where i drilled the holes for the vacuum. Not on that point, but it will give you an idea. The holes and plugs are on the botttom as mounted.
I've seen pictures of the bike throttlebodies used, they appear to have a similar vacuum plug, but i didn't see anyone use this for the MAP sensor.
Greetings, soon to be a dutch megasquirter...
http://members.home.nl/schlappi/PICT002 ... 20view.jpg
http://members.home.nl/schlappi/motorke ... 20view.jpg
