aem wideband
Posted: Fri Apr 28, 2006 12:05 pm
by elturbonitroso
Hi guys i just got my aem wideband p/n 30-4100 and i have a ? in megatune i have to set it as aem linear and my other ? is do i have to put the 370 ohms resistor like the innovate lc-1.thanks
Posted: Fri Apr 28, 2006 5:30 pm
by 460stang
I am running an AEM unit. Not sure of the part number but it is the one with the controller built into the gauge.
I am not using any additional resistors. Is working very well.
Posted: Fri Apr 28, 2006 6:07 pm
by elturbonitroso
thats the one that i have so the reading in megatune and the aem is exacly the sames how you set it up in megatune as a aem linear.
Posted: Wed May 03, 2006 3:04 am
by elturbonitroso
i set up mine as AEM wideband linear and when i open megatune give me a warning that said no 02 sensor configuration anybody with any idea im using a ms1 v2.2 code 024s13 and megatune 2.25
Posted: Wed May 03, 2006 6:32 pm
by elturbonitroso
anybody with some advices
Posted: Wed May 03, 2006 7:23 pm
by tapedshoes
i have the same wideband methinks, but it uses the same voltage output as an innovate wideband. Dont set it as an aem wideband linear in your settings, set it as an innovate 0-5. Then go into lambda settings ini and look for the innovate 0-5 setting. change any "10" to a 9.5, as MS will read the AEM .5 points off otherwise. hope this makes sense
Posted: Thu May 04, 2006 11:54 am
by elturbonitroso
ok i do the change in the configurator as innovative lc1 and i dont get the error.
