Fuel Inj Sizing Question
Posted: Fri Apr 14, 2006 11:15 am
by sha_ba_do_bang
I just found some injectors and i crossed the part number of them and they are out of a 91-95 Toyota Trecel, with a 1.5l engine.
I am turbo charging my 1.6l VW air cooled engine and using megasquirt edis, I plan on hooking them up and measure their volume but do you think they are to small? I don't think they will be big enough so should i even waste my time checking them?
Brendan
Posted: Fri Apr 14, 2006 12:00 pm
by woh
It may be OK.
Some cars use oversize injectors. Check the PN there may be some flow information on the web.
Posted: Fri Apr 14, 2006 12:51 pm
by whittlebeast
Posted: Mon Apr 17, 2006 11:59 am
by sha_ba_do_bang
I found the distributor and he has specs for all the other injectors except this one, he buys them right from Toyota so that will be impossible to find the flow rate.
I measured the resistance and they are 16ohm so thats good, i guess i'll hook them up to a fuel rail and measure their output.
I'm leaning towards these not working because they were only used in 1496cc engines and i want to use it in a 1600cc with a turbo, i'll measure them and see what happens!
Brendan
