running well hot, but too rich in warmup
ochizon
Post by ochizon »
I tuned my truck hot, then tuned the warm up while sitting, and got the idle decent through the range. Now when I DRIVE while cold, it is soooo rich that I am getting stutters, specifically is seems from the overlap between AE enrichment and startup enrichment.
So this begs the question: Do the startup enrichments work all around the map? CAn I limit them to idle only?
