AFR table for aircooled?
Posted: Mon Apr 10, 2006 9:51 pm
by jkeyzer
Hello,
I have been following Megasquirt for years but have only recently been able to actually get a system installed in my car. It is a 1972 Porsche 914 with a 1.7L type IV aircooled flat 4 engine.
I just upgraded to MSII and I have a couple questions.
Is there an AFR table available that is oriented towards aircooled engines (AFR target ~13.5 cruise, 12-12.5 WOT if I am not mistaken)? Comments on desired AFR for aircooled are welcome as well.
Second part to that question - is there an AFR table generator available? Entering 12x12 tables by hand is tedious to say the least. :) In general how should AFR vary vs. RPM and vacuum?
If I have made the newbie mistake of not using the search function properly please bear with me! :D
Posted: Tue Apr 11, 2006 5:58 am
by agrump
Attached is my AFR table for my 914-4. I set cruise at 13.2 to keep head temps in check. You probably could go leaner near idle, my cam forces me to have it a bit fat. Top end is set to 12.5
Posted: Tue Apr 11, 2006 12:48 pm
by crash914
You can have a copy of mine...it is rich but works.
my motor is a 2.7 big 4 with 36# injectors. It should give you something to compair to...herb
