MS-II with EDIS ignition only
RdSnake,could go ahead and start wiring up my MS-II with EDIS and run ignition only for now.
Yes, there's no reason you couldn't do this. Just don't hook anything to the injector drivers (no fault codes, etc., will be set in MegaSquirt).
In fact, doing it this way simplifies things since you can assume your fuelling is good until you get the ignition sorted, then you can add fuel control and get that sorted knowing the ignition is good.
jakobsladderz
Metallargy
