MS-II Suspect Faulty
Posted: Sat Apr 08, 2006 9:41 am
Dear All,
I am having a problem with my MS-II. It's in a v2.2 board,+12v
connected to pin 16 of CPU socket. Version 2.35 firmware installed.
When I open the Realtime Display window in MT and move the O2 pot
fully CW and CCW, I can only get a reading of 400mV on the display.
My multimeter tells me that the voltage is changing from 0v to 1.1v
on Pin 28 of the CPU socket. The other analogue inputs seem to be
responding correctly to their input values. If I remove the MS-II
CPU and put in a MS-I CPU (with pin 16 removed for the +12v supply
onto the MS-II) running v3.0 firmware, then MT Realtime Display
correctly shows the O2 sensor voltage. I conclude that my MS-II is
faulty somehow, like a damaged analogue input, but is there any other
possible reason for this? I am using Megatune 2.25 latest version
Thanks, Dave.
Thanks, Dave.
