injectors spray contiuously
Karl
Post by Karl »
I have MS ver 3 with Mn&S 024s13. I just about have the ignition worked out but now I have a fuel problem. When the fuel pump turns on the injectors start spraying contiuously filling the cylinders fuel of gas. I disconnected the wiring to the injectors and they do spray at all. What setting could I possibly have wrong that would make it do this. These are low impedance injectors
Karl
