i have a problem
mac95
i have a problem
Post by mac95 »
i have a dodge neon with the ms install. the problem is when i install it i automatic idle at 800rpm . now the idle fall on 500rpm . i adjust the srew on the t/b to idle it back at 800rpm . and after the car warm up if falls back at 500rpm. is there something wrong with my ms it control fuel only
