tuning for economy: where and how lean can i go ?
mops
- Experienced Squirter
I'm driving my machine and fuel economy is not bad, i.e. comparable to stock ECU. However I'm sure I can lean out there and there. I got LC-1 WBO
Basically I'm trying to tune my engine for really good economy up to 3krpm and for absolute max power over that.....
My question is.... (this only applies to rpm below 3krpm):
is it ok to run long time lean, by lean I mean 15 to 16 afr's... my car might run lower in some cases, is it fine to lean it out to 17 on cruise ? consider that daily i drive gently, so this engine will be driven daily on lean, so basically 90% of milage will be done lean.
I guess my question is whether it might damage/reduce lifespan of the engine ?
Ideally I'd like to tun over 16 afr's on cruise, around ~15 for light acceleration (up to 75kpa), then for WOT I run 12.5-13afr's...... I think with some good, fine tuning this can be achieved, I'm just concerned whether it is actually healthy for the engine to run that for extensive periods of time.....
I think with good tune, more power than stock ecu can be produced AND fuel consumption might be reducted significantly (up to maybe 20%)
jakobsladderz
As for the rest of the combustion chamber, I think it's fine to run lean at light load. Keep in mind that best economy will be found close to 15.5:1 on petrol. Leaner than this and you start to have more unburned hydrocarbons going out the tailpipe and economy again suffers (basically, the pockets of lean mixture in the chamber that won't/can't ignite get biger and bigger till eventually you will get noticeable misfire). This may not apply is special cases (high turbulence motors, GDI) but is generally the case for 'normal' engines.
