LOW IMPEDANCE INJECTORS
earlyhemibill
Post by earlyhemibill »
According to the computer at Hilborn I will be needing 75 lb injectors. They have the low impedence units. Will the Megasquirt system be strong enough to run these on my V-8?
earlyhemibill,
Yes. I run 72 lb/hour low-impedance injectors on my car at the moment.
earlyhemibill
Are you running more than 4 injectors? Do you know what amperage these pull or does it matter?
