relay board
timkel
relay board
Post by timkel »
Is there going to be some kind of relay board for the micro. It would make changing from carb to EFI on a motorcycle a lot easier.
It should work with the existing relay board. The interface cable would, of course, be different.
timkel
Post by timkel »
I just needed the 3 relays and the fuses not the whole relay board for the ms. They should be enough room for that above the micros board.
