Overrun fuel cut
Posted: Thu Mar 02, 2006 11:10 pm
by teg
Where can I set overrun fuel cut parameters in MS2?
Posted: Fri Mar 03, 2006 10:13 am
by wes kiser
You currently don't set them as overrun parameters. What i did on mine, was I added a row of low map (less than 20kpa) values, that I only enter when on overrun, and then just made my ve value a couple of percent at the rpms I wanted overrun fuel cut in that row. For example, from 3500 down to 1500, I have less than 5% for my VE on that row (20kpa), and then blend it into the table above and below a little to keep it smooth.
Posted: Fri Mar 03, 2006 1:42 pm
by teg
That isn't solution, because I want 1 second delay to fuel cut and it should be disabled when engine is cold.
