MS2 pcb v2.2 fuel only and coil trigger
teg
Post by teg »
Is that impossible? Why?
78Spit1500Fed
Post by 78Spit1500Fed »
The MS2 on a V2.2 PCB will control fuel only very nicely. What gives you the impression that it's not possible?
-Brian
teg
Post by teg »
I have an installation where it works perfect with MS1 and not with MS2 and also MS2 installation says that it isn't possible (Of course just in ignition case, I think).
whittlebeast
Post by whittlebeast »
MS2 it a little more sensitive to the tach signal but it also has lots of built in filters to tune out noise. See general settings lag factors.
AW
teg
Post by teg »
Got that rpm measurement working by tuning "lag factors" or as we call it in our ECU - filter constant.
