Injector Sizing
sha_ba_do_bang
Injector Sizing
I'm building a 1900cc VW bug motor with stock parts so far (i'll replace when i blow it up) I'm using a garrett T25 turbo and made a custom intake and exhaust plumbing. I've seen one guy use 37lb injectors but then i just saw someone use 19lb. What do i need?
I'm hoping for 200 hp, i want to keep the boost down for now around 9lb until i replace the crank and such. What sixe injectors should i get?
It doesn't make sense that someone ran 37lb and someone else did 19lb
does it?
I will be running EDIS ignition
thanks
Brendan Burke
19# injectors could be used but would have to be run at very high pressure or 100% duty cycle - neither of which is a good idea to plan on. I am assuming the same 200hp target - which is a stinkin' lot of ponies for a stock air cooled veewee...
If you haven't checked it already, you might get some interesting info from Kirkwood over at http://www.dune-buggy.com/turbo/index.htm
elturbonitroso
