Mechanical fuel pumps and surge tanks
Charlie G.
I am considering using a mechanical fuel pump to supply a surge tank. Would like some input on how continues full flow may effect pump life as opposed to working against a float valve.
This fuel system will be used on a 383 HP Mopar with the standard fuel pump supplied for that engine.
Also somewhere on this lest (I think) there was a description of a fuel pressure sensor used on Ford non return fuel injection systems. Does some one have a few year and model numbers that would have this sensor?
66 Plymouth sattelite 383 HP
Port injection with fuel ready Quadrajet used as throttle body and backup.
MS V2.2 in use
MS V3.0 ready for MSnS-E in near future.
I can't help you with returnless systems, but I haven't heard of anyone building one DIY successfully so far. Vapor-lock and PWM drivers seem to be some current hurdles to DIYers.
http://www.msefi.com/viewtopic.php?p=91782
http://www.msefi.com/viewtopic.php?p=34961
I have also heard of people doing the same thing on returnless models of the same car (not all models had the fuel return line) with no troubles
