Crane Fireball XR and MSII
Adam Dustin
the next thing i will try is taking the signal after the amplifier box, but i dont know if msii has enough juice to effectively trigger the coil.
any info out there. anyone done this before.
Adam Dustin
im hoping im not s.o.l. with this ignition system. would be a terrible waste of money.
What you need is a transistor - these are amplifiers by nature. An NPN transistor hooked to a 5 Volt source (collector) and ground (emitter) with a resistor to limit the current, and switched by the optical sensor (again with a resistor to limit the current to the base) will do what you want.
There's an intro here: http://www.technologystudent.com/elec1/transis1.htm
For a practical solution see: http://www.msefi.com/viewtopic.php?p=93343#93343
Adam Dustin
basically what im asking is can i run a simple 12v transistor or do i need to bring the voltage down (with resistor or voltage regulator or alike) before and use the 5v transistor described in the link above.
Adam Dustin
