Idle problem
cashsaudio
Idle problem
Jeff
cashsaudio
Re: Idle problem
Jeff,cashsaudio wrote:I had this for about 9 months and i decide to replace the msd 6a and blaster 2 coil but i have the MS out to do some major interior work and then after hooking up everything started up and then it dies I was like "huh". Now been messing with the enrichment, constants, everything that i could think could go wrong. Took the plugs out and its all black which means its rich. Sometime it will stay idling but if i give it a quick rev, then it'll die when it goes back to idle. What is causing this? I had this working perfect over the summer then put everything together within the last 2 weeks and well the weather is cold. I really need to fix this so i can get to the ice drag races. Btw, I also have a problem when it won't go pass 5500rpm what causes that? It act like its sputiering (can't spell) out. Thanks
Jeff
Your problem with not being able to go past 5500 rpm may be due to having the rev limiter turned on. - I think 5500 is the default.
As far as your idling problem, does it occur after the engine is fully warmed up ? If so, then there may be noise on the tach input either due to the new coil or the hookup of it. Only two things changed since the summer - the weather and the new coil. If the problem occurs after the car is warm, its probaly not the weather. So you need to look at your rpm and verify it is stable and reasonable. Another possibilty is you need cold accel enrichment. If the car is warm and just left to idle, is the idle good ? Does the problem just occur when you step on the throttle ?
cashsaudio
Thanks for your response.
Jeff
I forgot to tell about the cold accell enrichment its at 9.0 and the %age is 100
mops
- Experienced Squirter
i had spark issues with my MS and once i sorted them out it runs beautifully...
if i was you i'd hook up timing light and see whether timing light firess of when the engine is stumbling... if not then you are getting no/weak spark and thats your issue...
