AFR Table where to start?
Mad Professor
Can someone please help me out with making a new AFR Table.
Min MAP: 20 KPa
Max Map: 200 KPa.
Idle: 950Rpm
Rev Limit: 6000Rpm
What other data will I need to help me make a new AFR Table?
Thanks for your time.
Mad Professor
dbubb
I'd try leaning out the cruise region i.e. ~50kpa to 16.
Then I richen the region from 100 kpa and up. try 13.5 at 100kpa and somwhat richer than you have in all regions above that.
Also, you'll probably need to richen the 800-1300 rpm and 20-100 kpa part of the map to around 14 so it'll idle decently.
How lean one can go depends really much of the engine design and that you have to experiment yourself. E.g. I can't go any leaner than 15.5 really as at 16.0 I get driveability issues. The idle AFR settings depend solely on the emission levels one is targetting. I run mine rich at ~14, because emissions are not an issue and it smooths the idle because of the largish injectors I'm running with MS-I.
captain16vgti
daxtojeiro
- MegaSquirt Guru
Phil
http://www.replica-cobra.co.uk 5.0L TVR powered Cobra Replica (MSnS-E)
Mad Professor
