MegaTune installation problems and cure
Posted: Sat Dec 17, 2005 10:53 am
DIALOG BOX DROP-DOWN FAILURE: I found a string where Bill Steele was having identical problems with MT. When left clicking on the subject above the dialog box, nothing would happen. The cure was really simple. Just click on the subject and move the cursor down to where the dialog box is supposed to appear and, in about a second, it will appear. A little more on this later.
MTCFG.EXE FAILS TO OPEN: I found a string titled "Question for patient soul" in which is described the existence and purpose of a program called "Dependency Walker." I downloaded it into Program Files from a site found using Google http://www.dependencywalker.com/ , and ran mtCfg.exe through it. The result showed 3 system files that my laptop was missing and which were needed to open mtCfg.exe. Again, Google provided numerous sites where I could download the files in zipped format. One suggested that I download WinZip to open the files, so I also did that, and placed it also into Program Files. The three files that I downloaded were apphelp.dll, msi.dll, and userenv.dll, which I placed into C:/windows/system. I then went back to WinZip and did a zip file search to locate all of the zipped files on my laptop. It appeared that I had failed to unzip the 3 files, so that needed to be done.
You can imagine my disappointment and frustration when mtCfg still failed to open. The cure, after considerable anguish and beating of chest, was easy. I uninstalled MegaTune entirely from my laptop, and reinstalled the latest version, which was MegaTune225b715. I then went to Eric's download instructions and explicitly followed them about changing the Megatune-II.ini file to match my firmware (File -> Activate). Following through the setup prompts, I was able to open both MegaTune and mtCfg. It was a great feeling! The gauge colors are beautiful.
You can imagine my disappointment and frustration when, coming back a few hours later to relish my triumph of man over machine, MegaTune refused to open from my desktop shortcut. I went to Windows Explorer and opened up MegaTune with success. It then dawned upon me that the shortcut was created prior to me changing the megasquirt-II.ini file. With near feverish excitement, I deleted the desktop shortcut, opened up Windows Explorer, and created a new shortcut.
You can imagine my trepidation as I moved the cursor to the shortcut, held my breath, and double-clicked. I was either going to soar like an eagle or go down like a flaming chicken hawk. MegaTune opened up!! I could already feel the wind in my face! To my continued surprise, even the dialog boxes dropped down just as they are supposed to do. Go figure!
I hooked up my MegaSquirt to the laptop, connected the Stim, and took her for a test drive. It was exhilarating!
The moral of this story is that attempting to understand how computers operate is very daunting and mind numbing in the extreme, especially for us older people. If you have trouble with MegaTune working properly, and then screw around with it some, then it is best to uninstall the program, reinstall with the latest version, and be very careful to follow Eric's good directions to the letter when configuring MegaTune.
Good Luck,
Chuck
