The 68-2 is all over the place, it just spike after spike, you must have a lot of noise on this or it must be set wrong.
Base Ignition Settings
- Master Squirter
Re: Base Ignition Settings
hufferfuely
24c wrote:I looked at your no tooth msl, and there are a load of trigger± in that log, and a couple of tach resets. You want trigger± to be zero, and no tach resets.
The tachref is clean as can be..... This setup is clean with wiring run seperately and nothing close to the vr sensor. Not sure how it could be any simpler, unless the code doesn' like that number of teeth.
hufferfuely
Assuming for a second I could get the processor to recognize my signal as two evenly spaced teeth (it is phsically) wouldn't I need to setup as a two tooth wheel with 0 missing teeth and zero skip teeth so that is would calculate the correct RPM.grippo wrote: You have to get a setup that has 1 sensor and produces 2 evenly spaced pulses per rev. In this case use NON-dual spark, 0 wheel teeth. This would be equivalent to a standard distributor/ reluctor setup.
Do you think the super long teeth are the problem?
- Master Squirter
Do you have super long teeth? I thought it looked like that flywheel you posted, if so, no problems, as tooth log is from one zero cross to the next (simplified), and you would have two events per revolution.hufferfuely wrote:Do you think the super long teeth are the problem?
I'll have a look at the manual,as you seem to be missing the point re definitions. I realise that the description in the manual does always align with the teeth options you are presented with in the software dialog boxes.
If you set it up as I said, I believe you will get the right rpm. In any case, I want you to get started, we can deal with an rpm that is double or half true value when you have a running engine. I don't like to use the toothed wheel option for something that really isn't a toothed wheel. It may work but I haven't had experience with it.hufferfuely wrote:
The long teeth shouldn't hurt if the sensor is matched to the tooth. Since this is an OEM setup I would expect it is.
That is probably why you aren't getting it to put out rpm with the 86-2 wheel if you say it is a clean signal on the tachref. As far as I could check you have the teeth set right, you just need to select dual spark option: single crankwheel with missing teeth and you should be able to get sequential 2-cylinder.
