Page 3 of 3
Re: Microsquirt RPM not reading with coil
Posted: Sun Aug 11, 2013 7:29 pm
by dontz125
Which manual was this? The
EDIS section in the uS manual says to use the OPTOIN+ (AMP 30) for PIP, OPTOIN- (AMP 31) to the EDIS module ground location, and IGNOUT (AMP 12) for the SAW signal to the EDIS module.
Posted: Mon Aug 12, 2013 8:37 am
by Shock_Strauss
I noticed I was using a writeup for msextra... I followed the link you sent me but now there's no rpm signal. I don't have to jumper anything correct? Thats only for Megasquirt not uS? Also, I found this document
http://www.useasydocs.com/theory/vr.htm. Do I follow the table near the bottom for Hall or Opto input?
Posted: Mon Aug 12, 2013 8:53 am
by dontz125
Ah - there we go. I *knew* I had seen an updated write-up on the uS inputs ...
The EDIS page says to connect the PIP signal to OPTOIN+, and the new input page says to connect VR+ to Vref when using the OPTO circuit. Try that, see what happens ...
Posted: Mon Aug 12, 2013 9:30 am
by Shock_Strauss
Nope, still nothing. I connected it to vref then tried +12 like it said. What's strange is why is it getting RPM when I connect vr - to the pip signal...
Posted: Mon Aug 12, 2013 9:52 am
by dontz125
Like the man said, "Whatever works, baby, whatever works!"
Posted: Mon Aug 12, 2013 2:26 pm
by Shock_Strauss
So, since I could only get a signal by following the msextra write up, I went ahead and installed it on my uS. I'm getting a crank signal and the injectors are firing beautifully!
Thanks for helping me out dontz125!
