Loss of spark / revs
nakedninja900
Re: Loss of spark / revs
OK I've set up the timing light and I'm getting a good signal however the engine wont run ,it keeps throwing the spark advance into a negative number (-14deg) and then back to what I set (8deg) so it keeps kicking back, from what I can see when it sparks at 8deg its not far off but I cant understand whats telling it to advance so far.From what I can tell with the timing light it alternates between -14 and 8 every revolution.
nakedninja900
How do I upload a data log? its keeps trying to upload the complete magaviewer.
nakedninja900
I have the advance set at 4deg
nakedninja900
I'm booked in for a dyno run on Saturday so we'll see how she runs. I'm having no joy with the tachometer though, I'm running an aftermarket Koso unit but there's no info in the manual about the Tacho out wire, does this give a positive 12v pulse?
Matt I seem to be having a bout of stupidity but I still can't post the datalog even though I posted an msq on the previous page I can't remember how I did It!
Help I'm stoopid.
nakedninja900
nakedninja900
The main problem is the ignition advance changing to a negative number when cranking , once started its fine but it really struggles to start. I have the dwell set at 2,5m/sec but it stays at 2,0m/sec.
- Attachments
- CurrentTune.msq
- (30.04 KiB) Downloaded 208 times
Have you tried changing the Cranking Trigger setup from Trigger Rise to Calculated?
