Page 3 of 4
Re: microsquirt still not firing
Posted: Thu May 27, 2010 11:33 am
by Matt Cramer
Use single tach input, 18 skip teeth, 9 delay teeth.
We never tuned a Zetec on Microsquirt B&G code, so I don't really think any of our files would be right for your combination.
Posted: Thu May 27, 2010 1:06 pm
by 109e
Cheers Matt
Tried those settings but no luck, no rpm now, MAF stopped working too but maybe a wiring thing, not using MAP.
Attached is a datalog and an msq if any help
The attachment megasquirt201005272155.msq is no longer available
(25.11 KiB) Downloaded 55 times
Posted: Fri May 28, 2010 4:16 am
by Matt Cramer
How is the crankshaft position sensor wired up?
Posted: Fri May 28, 2010 9:47 am
by 109e
Ita a 2 pin ford item, one terminal is connected to the coax shielding which then goes to the ampseal, the other is connectec to the white wire inside the coax which again goes to the ampseal, the coax wire coming from the microsquirt has IGN stamped on it.
Posted: Fri May 28, 2010 1:24 pm
by MOLECULAR BOB
Hi there
I am not sure 'cos it's a while since i read the manual, but i think the sheilded white "ign" wire is an ignition output and will be pin 11 or 12. You should be using the optoin or vrin wires i think for a ford crank sensor, cant remember which at the moment, but ford call the crank sensor a Vr sensor so probably need to use the Vrin wires.
Check your wiring as the first option
Posted: Sat May 29, 2010 8:53 am
by 109e
hi, its connected as per manual, the vrin1 is the grey coax marked as IGN, might try the optoin wires as i can use either one or the other according to manual, worth a try i suppose
Posted: Sun May 30, 2010 5:48 am
by 109e
Matt
(25.11 KiB) Downloaded 47 times
Still no luck, tried those settings which reduced the rpm quite alot, have attached an attempted start datalog and msq
Cheers Chris
30thmay.xls
(61.5 KiB) Downloaded 47 times
Posted: Mon May 31, 2010 10:27 am
by 109e
Hey it started !
Increased the amount of fuel the injectors wanted to 2 and it fired, running fast and popping back so still not right, attached a datalog of when its running and the msq i am using, any help is appreciated
Chris
datalog201005311726.xls
(28.44 KiB) Downloaded 49 times
startsrunsbad31may.msq
(25.12 KiB) Downloaded 53 times
Posted: Tue Jun 01, 2010 7:33 am
by Matt Cramer
See if you can check the timing with a timing light and make sure it's in the ballpark.
Posted: Tue Jun 01, 2010 12:49 pm
by 109e
Matt
Probably a silly question, but if i do manage to get a timing light on it, how do i adjust the timing in Microsquirt? I dont have the idle valve, maf or map sensors connected, would this affect idle? Its ticking over at 3000 rpm as per datalog, a tad high lol.
