Need some help with this Vtwin....please!!!
Re: Need some help with this Vtwin....please!!!
In your setup you need 2 coils because of the odd angle between cylinders, meaning you can't fire them simultaneously as in normal wasted spark. That being the case you must have 4 separate coil charging/ firing events per 720 deg cycle, so skip teeth must be 12, rather than the normal 24 teeth for pure (1 coil) wasted spark. What determines rpm is no. cyclinders, but also the particular dual spark option, 2 or 4 stroke and, in the case of 2 cylinder, the odd angle is also a factor. If you have 2 cyl, odd angle NOT equal to 0 and skip teeth = 12, your rpm should come out correct for a 2 coil setup. If that is the only problem, the rpm can be rescaled to come out right by changing the scale factor in the ini file, but it shouldn't need to be.
I also recall that I had a problem with the rpm's reading wrong. What it was that when I specified 2 in the number of cylinder and burned it to the ecu it was not changing the number. Eventually for some reason it started working right and the rpm's were OK.
If this doesn't work I may have to drag out my test stand and see what we can work out.
- Attachments
- modified.msq
- (23.61 KiB) Downloaded 89 times
tech3sandcars
I did change the skip teeth to half my trigger wheel tooth to run wasted spark and it spark coil B at same than coil A so don't seem to work in my case.
Just out of curiosity; what kind of Kawasaki engine are you working on. I would assume it is an atv by your screen name.
tryskriel
If you post your msq or your ignition setting we could probably help you. There is no reason this should not work on a Harley, the same as any other v twin.
tech3sandcars
Thanks again.
Bottom line though, Microsquirt combined with the LS coils on a 90 degree vtwin can work very well.
Here are the settings that made the spark come out where we wanted it;
Teeth 18
Missing teeth 1
Skip teeth 18
delay teeth 7
offset #1 -115 degrees
offset #2 80 degrees.
Our wheel looks like yours, missing tooth, then 'TDC#2, then TDC #1
I did a lot of experimenting to get to these settings. Tried 9 for skip teeth, RPM went from 500 to 1000 ??? TDC #1 is 7 teeth from missing tooth. When I tried 8 for delay teeth, RPM went to 250.0. Also entry for offset #2 is difference between TDC #1 and #2. Found that offset #2 must be positive. Any value more negative that -30 and there is no spark on #2 cylinder. These are what I call SUFs, special undocumented features.
So we ended up wit the timing at 10 degrees BTDC for both cylinders. Cranking RPM is 250.0 which seems correct, not sure.
Then we had fuel problems, but thats another story.
Elliott
Good luck. Let me know how it works.
Elliott
