I'm sorry thought I did. 36-1 wheel TDC #1is at 20th tooth, #2 is at the 2nd tooth so its set at delay 18, Skiip teeth 18 off set -4 . It idles real well that way anyhow .I do have resistor plugs in it but not the caps. I will post any other changes and MSq's
Well Theyjust called it the event is over In about 2 hours. I just wanted to thank everyone who helped me this week. After this Iwill have more time to post a little better. I finally did a datalog and found it keeps dropping crank signal on and off at about 3000 RPMs I think its a RF signal problem.
Thank you Everyone for your help,
Lewis
well its been a few weeks since I had time to play with the bike. Playing with it today I had the 95K resistor wired the way they had it in the instruction for the VR sensor as it turns out this is the set up for testing the sensor on a scope and not for running it so I repositioned the resistor so its in series with the + of thr VR sensor and it revves fine also had to disconnect the charging system
